Posted by Janicholson on May 22, 2014 at 12:12:19 from (199.17.6.78):
In Reply to: fire out of exhaust posted by KarlO on May 22, 2014 at 10:19:18:
Static timing is set with it not running on TDC compression #1 cylinder. The centrifugal advance (distributor only) is much farther advanced, and is controlled by weights and springs in the distributor (under the breaker mounting plate) The rotor should feel springy if turned clockwise (less than 10 degrees) if it does this, and returns to where it was before, it is probably OK. If it does not turn, or turns and stays in either direction, it needs advance system repair (or a rebuilt distributor) Having no advance will make it do the flame trick! Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
