Posted by Bart Hull on May 22, 2014 at 14:26:45 from (184.101.140.72):
Mowing the lawn with a 5ft brushhog, running 3/4 rpm (no tach) for 3 or so hours. When I tried to reduce RPM with the throttle it wouldn't come down, even pulled kill cable, no dice. When I pulled PTO out of gear it sped up more. Finally had to re-engage PTO, put in 2nd Low and drug the brakes to load the engine and then was able to reduce RPM and then kill the motor.
Strange. I fired it right back up did some more mowing and was able to reduce throttle and kill as normal.
Wasn't running hot, it was in the "Run" zone on the temp gauge but it is a 104 degree day here in sunny Arizona. I've been flushing radiator out as it has lots of crap in it and just changed the oil after the high rpm run today.
This has the early pneumatic CAV Diesel injection pump (Tractor Serial number 1420) 1960.
Any ideas? I'd hate to blow up the motor from over-revving it, cuz I have lots of work for this old gal to do around here.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
