Re: Super C with 240 Governor
Posted by gene bender on May 22, 2014 at 17:38:37 from (67.55.226.121):
In Reply to: Super C with 240 Governor posted by Bohn Super C on May 22, 2014 at 13:32:36:
You need to unhook the pin in the clevis with engine off open throttle. Now hold carb open and adjust the clevis so the pin will go in. Its possible the 240 mite have a longer rod but you will know when you do the adjustment i described. It will not be hard to make a new one if the present one is too short.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
