Re: air in the sdiment bowl
Posted by 36F30 on May 22, 2014 at 17:56:27 from (97.125.133.93):
In Reply to: air in the sdiment bowl posted by TEXAN Connection on May 22, 2014 at 16:22:22:
Heavy load causing higher operating temps, boils gas in the line and viola....VAPOR LOCK. The bubbles in the tank are vaporized fuel. Gravity pulls fuel down, bubbles force it back up, engine starves for fuel. Won't return to normal flow until the temperature drops on whatever is heating the fuel line. Hard to say whats doing it without seeing and knowing if you fuel lines are stock, rubber hose, inline filter, etc...etc... Sometimes something as simple as a wooden clothespin clamped on a steel fuel line is a good enough heat sink to stop it.
