Posted by Owen Aaland on May 22, 2014 at 17:56:40 from (216.47.33.5):
In Reply to: air in the sdiment bowl posted by TEXAN Connection on May 22, 2014 at 16:22:22:
From your description I would say you have fuel boiling in the fuel line. The vaporized fuel is bubbling back up into the fuel tank.
This problem is usually called "vapor lock". In a vehicle with the fuel tank below the carburetor and using a fuel pump the vapor does not return to the tank but is trapped in the fuel line. The vapor has to pass through the float valve in the carburetor which keeps liquid from entering and the engine dies due to "Vapor Lock". In your case the vaporized fuel can escape back up into the fuel tank allowing some liquid to continue to flow down into the carburetor, just not enough to allow the engine to run normally.
Today's Featured Article - A Towny Goes Plowing - by Anthony West (UK). I live in an area renowned for its rural beauty. Small fields with hedgerows and trees are common place, as are small hamlets with village greens and the odd duck pond complete with swans. The center of any village once the shop is closed is the old tavern. Rustic places with cheerful names like "The Griffin" "Red Lion" or "The Plough and Harrow" are found dotted around the country lanes all over the place. The warm glow of yellowish light can be seen for quite some distance at dusk, and
... [Read Article]
Latest Ad:
[More Ads]
