Re: fire out of exhaust
Posted by KarlO on May 22, 2014 at 20:17:16 from (184.195.77.107):
In Reply to: fire out of exhaust posted by Matt Tieken on May 22, 2014 at 10:19:18:
I'm pretty sure the wires are correct. If number 1 is at the fan end it fires 1,4,3,2... Holy cylinders bat man! It's supposed to be 1.3.4.2!
Sheesh, I've got the carb in the shop and I can't try it until tomorrow. Boy do I feel sheepish. When I changed the plugs I must've put the wires on wrong. The length of the wires fit much better as 1,4,3,2 (I didn't change them). It's been running like this since the beginning of last summer. I can't believe it starts and idles so well.
