Posted by M.Genrich on May 22, 2014 at 21:43:46 from (70.197.232.25):
In Reply to: fire out of exhaust posted by KarlO on May 22, 2014 at 10:19:18:
I had a like problem with a 656 hydro that I overhauled a few years ago. It ran fine until it was under a load on a feed grinder then it would start to miss spit sputter and then die. thirty second later it would start right up and run fine again until you put a load on it. That was the day I learned that D21 plugs were to hot for a engine in good shape under a load. put a set of D15Y plugs in it and its ran fine every since.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
