Re: 200 still running rough and VERY hard to start
Posted by mike van on May 23, 2014 at 02:34:31 from (24.151.25.186):
In Reply to: 200 still running rough and VERY hard to start posted by clint s on May 22, 2014 at 18:28:12:
Just my 2 cents, emery cloth on points is not the way to go - The
thin layer of nickel that those points were once coated with has
probably long been sanded away by it. The contacts are probably
rounded over now, not flat like they started out. Replacing them
would help a lot.
Today's Featured Article - What Oil Should I Use? - by Francis Robinson. I keep seein this question pop up over and over again in discussion groups all over the web. As with many things there are often several right answers and a few wrong ones. Some purist I'm sure will disagree to no end with what I will tell you but most of us out here in the real world don't really care do we ? Some of them only bring their noses down out of the air long enough to look down them anyway. If you are like me you are only doing this old tractor stuff because you enjoy it. You ... [Read Article]
