Re: Super C with 240 Governor
Posted by mkirsch on May 23, 2014 at 05:15:59 from (65.199.189.6):
In Reply to: Super C with 240 Governor posted by Bohn Super C on May 22, 2014 at 13:32:36:
If nothing else, Gene's description of the timing/adjustment process will also allow you to figure out the correct length for the throttle rod.
Again:
1. Engine off. Wide open throttle.
2. Remove pin from clevis end of throttle rod.
3. Hold carburetor in wide open position.
4. Adjust clevis until pin slides through everything easily.
You might be able to get enough by adjusting, or at least you can see how much shorter the rod needs to be. A new rod can be fabricated from a piece of steel from a hardware store pretty easily, if all else fails.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
