Re: farmall 400 drawbar
Posted by truckerlary on May 23, 2014 at 18:51:25 from (207.141.127.201):
In Reply to: farmall 400 drawbar posted by Kevin Roberts on May 23, 2014 at 18:00:09:
You could probably make one if you so desired. Take a regular swinging drawbar and cut it to size and redrill the holes. The part that went over top of the insert that held the drawbar up( the roller on a regular drawbar tractor) only went half way or so over the insert drawbar and was only fastened on one side. I hope you can understand this definition. Larry
