Re: farmall 400 drawbar
Posted by D Slater on May 23, 2014 at 19:41:52 from (184.14.181.112):
In Reply to: farmall 400 drawbar posted by Kevin Roberts on May 23, 2014 at 18:00:09:
If you have the 2 point hitch that has parts that mount on top of the transmission top? Swinging drawbar for that was a channel iron one with thick metal welded on the front and rear. Also had a thick piece of steel that hooked over the 2 point drawbar. Need to weld something up on that for a roller or make a complete one.
If you have a 2 point with traction control? Has a handle with notches on the left. Swinging drawbar for it was solid steel bar and also had a steel opening welded on top that hooked over the 2 point drawbar.
Don't know your location but I have one of those drawbars someone modified to use a roller. Would sell reasonable.
