Posted by Janicholson on May 23, 2014 at 19:51:00 from (74.60.94.18):
In Reply to: mw brakes posted by Kevin Roberts on May 23, 2014 at 18:28:56:
As noted they are not compatible. The key to the disk brakes has two components: The first is the wear related to the cover(housing) and the surface on the tractor frame. This wear contributes to the poor braking force due to bad angles on the internal linkages. The total clearance should be about .040". If the disks are thick, measure the total stack by placing the components in the housing while it is on the bench. The amount that it is recessed into the housing is that measurement. Milling the housing surface (where it meets the tractor, reduces the measurement. The second thing is clean smooth ball ramps, round balls, and good springs. I hope this helps. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
