Re: Timing??
Posted by Farmall4856 on May 24, 2014 at 04:13:51 from (70.192.204.217):
In Reply to: Re: Timing?? posted by Janicholson on May 23, 2014 at 19:53:47:
Ok I will check timing and also the coil.
