The points arcing and burning so quickly are from having 12 volts going through 6 volt points. Had the same issue when using an 8 volt battery on a six volt system.
An external resistor is wired inline between the ignition switch and the coil. Your coil may have an internal resistor, but sounds as though it has burned out, a common problem. The external resistors last much longer.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
