Re: Governor Rod
Posted by Bohn Super C on May 24, 2014 at 08:11:31 from (174.124.247.201):
In Reply to: Re: Governor Rod posted by tim11612 on May 23, 2014 at 20:00:38:
third party image
third party image
third party image
If my Farmall Super C has a Combine engine in it, that would explain a lot. The pulley on the front of the crankshaft has cross slots for a hand crank to engage in Four different positions , where all the other Super c's that I looked at has only Two positions for the hand crank to engage. Also my Engine has a pointer for the pulley for ignition timing. Also that would explain why the exhaust pipe, air filter tube, and the rocker cover tube are shorter then other Super c's that I have seen. The Number on the block behind the oil filter is 367826R2, as far as I can tell without removing the oil filter.
