Re: Behlen Power Steering Question
Posted by Ron in Nebr on May 24, 2014 at 20:31:53 from (70.198.6.68):
In Reply to: Re: Behlen Power Steering Question posted by SDE on May 24, 2014 at 19:41:57:
Thanks for the response. I didn't pull that plug on the side, just added more hyd oil through the cap on the top. Probably way over full now.
That plug goes in horizontally- it has a dipstick on it??
I did raise the front wheels off the ground with the loader and turned them side to side several times, basically followed the same procedure we used to use bleeding automotive power steering systems, but it didn't help much.
Read somewhere on here in the archives about cracking loose a hose up by the torque motor, but I tried that too and it also didn't help much.
