Nothing you do to or with the tractor (except put a big bore kit and turbo on it) could even begin to wear the differential. Drive it and work it as much as you want. on a car or truck with posi and 4X4 drive it does make a difference and the difference is thousands of miles going straight, 70 mph, and steering geometry that is dependent on same size tires. The tractor meets none of these. Imagine needing to put different size tires on a Farmall when doing contour plowing! you would need to change the tire from side to side to prevent ""wear"" when going the other direction on the side hill. Other than the looks, it is a non event. Jim
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
