Posted by jimb2 on May 25, 2014 at 11:55:41 from (99.240.243.222):
In Reply to: B414 Hydrualics posted by roaddevil49 on May 25, 2014 at 11:00:48:
Hi can you rotate the suction line? There is only an O-ring keeping the suction filter locked in. But after 50 years the O-ring could be rusted in place.
Re 3pt going up, I would suspect leaking control valve or something wrong with draft control circuit. There is a plunger by 3pt top link housing at rear of hydraulic housing. The plunger should move in and out with the draft control lever. If this plunger is not functioning then the draft control mechanism inside the hydraulic housing is not functioning.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
