Re: removing front pully nut IHC 460
Posted by El Toro on May 26, 2014 at 06:36:10 from (96.244.7.206):
In Reply to: removing front pully nut IHC 460 posted by motorstuff52 on May 26, 2014 at 05:32:25:
That air wrench should remove it. I would use a 6 point socket so you don't round off the corners on the hex head. Hal
PS: Should be turned CCW to loosen.
