The two hoses going to the cylinder provide up and down. One of them is the "extend" hose that lifts the hitch. If you feel the hoses when lifting to the top, (be careful) one will be noticably pressurized. (it usually has a restrictor in it as well to prevent extreme droping of the implement if a hose breaks) Lift the hitch and block it with a hydraulic, or highlift jack. Let the drawbar down on this jack to the location where the lift hose has no pressure. Carefully remove the hose from the cylinder (it may still have pressure, put a rag around it abd go slow), and cap it and plug the cylinder port to prevent it from leaking. Lower the jack to place lifting pressure on the bottom of the cylinder. If it now leaks down (it might take time if there is no implement on it) the packing/seals on the cylinder are bypassing oil. If it stays up, the valve may be leaking down. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
