Re: Super C LED headlights
Posted by Brian Schmidt on May 26, 2014 at 20:02:52 from (69.66.237.150):
In Reply to: Re: Super C LED headlights posted by Dan Nees on May 26, 2014 at 19:28:59:
Dan,
Several questions.
Are you running 6V or 12V system on the SC? The box says 2-24V. The website says 12-24V.
Do you think these are brighter than the incandescent bulbs you replaced? It is hard to tell from the pictures.
If 6V system, do you find that the generator actually can charge now with the lights on or is the tractor in discharge mode with the lights on?
Did you replace the rear work lamp too?
Does the light seem to be focused or a wide work light type beam?
Thanks,
Brian
