Re: Farmall b transmission issue
Posted by Roger46 on May 26, 2014 at 21:41:39 from (216.249.224.186):
In Reply to: Farmall b transmission issue posted by calcubman on May 25, 2014 at 21:48:32:
The problem with changing the gears that no one else has said is getting the correct backlash in the ring and pinion gears. If you don't get then correct they will first howl a lot and eventually be like the gears you took out. In the service manual it tell how to do the procedure. It is not a two minute job as you need to assemble and reassemble several times to get them set. That is what the shims are for. That is why it is probably easier to just swap the transmission as they are already set. Good luck. Roger
