Like others have suggested, you need to determine the cause of the bleed down before you start spending money.
If it turns out to be the cylinder, a new OEM cylinder would cost several hundred dollars, if you could even get one. CaseIH does not list the cylinder as an available part, so you're out of luck.
A hydraulic shop should be able to replace seals and o-rings in your cylinder for a couple hundred at most.
It's a tie-rod type cylinder, so you could tear it down yourself, even.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
