As Jim said they all fit only difference is rear rockshaft as the BN would be 8in narrower. There is one more the veggie model but finding one of them would be very very hard to find. There is a difference between the models for hand lift and exhaust lift on the lift assy. The hand lift models had two levers one shorter than other and exhaust had two levers the same length with one spring to lower when pressure was released they did had two levers same length for hand lift allowing just one side at a time to be raised and lowered and had two springs for ease of lifting. Most models you will find were for exhaust lift.
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
