Re: ih 56 planter
Posted by mkirsch on May 28, 2014 at 04:57:15 from (65.199.189.6):
In Reply to: ih 56 planter posted by rz farms on May 27, 2014 at 19:43:39:
The only advice I can offer right now is to pay closer attention to what's happening, and come back with a better description of the problem.
"Binding on the front drive chain" really doesn't paint a very clear picture, which is probably why you haven't gotten any responses yet.
What is the "front drive chain?" I'm pretty familiar with 56 planters and I'm not sure which chain you consider the "front" because they're all pretty much in the middle of the planter. Do you mean the chain that runs from the wheel? Do you mean the fertilizer drive chain? Do you mean the seed drive chain?
What exactly is happening when it binds up? Parts should be flying, or pins should be shearing. The drivetrain on those 56 planters is not strong enough to slide the wheels, especially if you're loaded with fertilizer.
The plates certainly wouldn't be the problem. They're plastic. If they bound up, the planter would just shred them. Take the seed boxes off and run the planter dry for a ways to see if it still binds up.
Have you taken a wrench and turned the shafts by hand to see if you can make it bind up?
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
