Re: case international harvester 946
Posted by DeltaRed on May 28, 2014 at 06:42:54 from (65.100.146.82):
In Reply to: case international harvester 946 posted by mel1943 on May 27, 2014 at 17:08:52:
Never heard of a "946".Is this a European or
Australian Tractor?Or do you have a 856, or 966 and
just mistype?You need an owners manual.All your
questions (and more) will be answered.On the two
afore mentioned tractors,the filler hole/dipstick IS
the hydralic AND transmission.Use 'Hy-Tran'.The
filter is below the brake pedals under/inside a
teardrop shape 'plate',held on by 6 or 8 small
bolts.
