Guess fifth worked before the trouble? Does the shift lever move to fifth or won't move to fifth? If it shifts to forth and 5th worked before, remove the belt pulley gear box or the opening cover to see if the fork and gear is moving, or if the teeth that lock fifth and the input shaft are the problem. If a fork problem the top cover needs removed. If a input shaft is needed the center section needs removed. If 4th and 5th slider and the input shaft is bad top cover and center needs removed. T/A clutch is supposed to release when the clutch pedal is depressed, same as what you do when pulling the t/a handle back. Need to adjust linkages.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
