Re: 200 still running rough and VERY hard to start
Posted by clint s on May 28, 2014 at 17:25:13 from (67.242.45.169):
In Reply to: 200 still running rough and VERY hard to start posted by clint s on May 27, 2014 at 14:42:01:
Started it and it started and ran good. Coil has 13 vol volts going in (+) and 6.6 coming out (-) Changed the coil to the new one and it would not start. After a bit it started and I turned it off and it would not start again. Cleaned the points and no start. Changed the coil back to the old one and no start. Finally the battery ran low and I threw it on the charger and called it a night. Any thoughts.
