Re: Super C hydraulics
Posted by Dean Olson on May 28, 2014 at 19:51:46 from (107.129.21.153):
In Reply to: Super C hydraulics posted by jhilyer on May 28, 2014 at 13:44:55:
You don't have to remove the seat box to service that. Disconnect both hoses at the cylinder and remove the 2 bolts the hold the block to the seat box and pull it and the 2 hoses out.
I had a problem with my SC's FH bleeding down and it was due to that valve leaking. I removed it and ran 2 new hoses from the auxiliary control valve to the cylinder.
It probably should be there if your not going to pay attention. Without it you could drop a heavy implement hard enough to damage it. I pay attention and slowly let implements down.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
