Re: where to order needle bearings for the C governor
Posted by Rick Remmert on May 28, 2014 at 20:35:06 from (68.103.4.23):
In Reply to: Re: where to order needle bearings for the C governor posted by SDE on May 28, 2014 at 19:02:28:
Sorry but I don't. The 504 spring was a direct replacement. What you might do is go to the archives and type in Super C governor. I had several post with questions when I did mine.
