Re: Super C hydraulics
Posted by Owen Aaland on May 28, 2014 at 21:20:56 from (216.47.33.5):
In Reply to: Super C hydraulics posted by jhilyer on May 28, 2014 at 13:44:55:
It is a double acting check valve used to keep the cylinder on the Fast Hitch from settling with a load on it. When the control valve is in not directing oil to the hitch both check balls are seated sealing off the cylinder from the valve. When the control valve pressurizes one side that ball is lifted off the seat to allow oil to pass. At the same time it moves a small piston in the block between the check balls which unseats the other ball allowing oil to pass back to the control valve. By controlling how much oil is sent to the cylinder you also control how much the other ball becomes unseated allowing you to control the speed even with a load on the cylinder.
Unless something is broken it is just a matter of replacing the O-rings to reseal it.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
