Re: 1586 hydraulics question
Posted by Owen Aaland on May 28, 2014 at 21:29:01 from (216.47.33.5):
In Reply to: 1586 hydraulics question posted by Dave H (MI) on May 27, 2014 at 19:46:01:
If you have the PFC system you can set the motor valve to have a constant flow and the other valves can use the remainder of the pump output even if they require higher pressure.
On the earlier system the control valve that has the lightest load will use all the flow until it reaches the end of travel and causes the pressure to rise so that the flow will go to the other valve. You can control this some by using restricters in the line but then the system will go on high pressure unless all the flow is being used between the valves.
