Re: 200 getting starter back together
Posted by gene bender on May 29, 2014 at 04:18:08 from (67.55.226.121):
In Reply to: 200 getting starter back together posted by clint s on May 28, 2014 at 20:48:56:
I rmove the end plate from the fields then having commutator plate free its easy to fasten it to the armature then slide the housing together with the drive end and all you need then is the two leads back to the en plate works same way with starters.
