Re: snowplowing with a Cub
Posted by George Willer on December 25, 2000 at 17:47:07 from (205.133.30.31):
In Reply to: snowplowing with a Cub posted by James (MO) on December 25, 2000 at 11:25:01:
third party image
John,
If you have the right place to use it, the belly mount can work as well as or better than a front blade. It will work very well to plow snow (move it sideways) rather than push it. The big problem is backing the front wheels over a pile. Otherwise, the weight of the blade is adding to your traction rather than subtracting as a front blade does. For a long drive that requires moving the snow aside, try your outfit before you consider any changes.
Post A Followup
: Re: Re: snowplowing with a Cub
