Re: H Oil Filter Conversion Kit
Posted by S2710 on May 29, 2014 at 11:01:57 from (207.190.76.146):
In Reply to: H Oil Filter Conversion Kit posted by Hillbilly_H on May 29, 2014 at 10:22:41:
Take the filter off and take the gasket out and if you don't have a groove that is deeper then what your gasket is you have old gasket left in the groove. take a small pick or screw driver and tap it in the groove and if you have gasket in there it will come out in pieces. Clean the groove out good and put a new gasket in and put the filter back on and when you are tighten the bolt hold the can so it doesn't turn and ruin the gasket. Also I have seen where the gasket leaked on the part that is bolted to the block.
Bob
