I used regular ole hardware store grade 5 bolts in mine from Rural King (buying them by the pound makes em quite affordable).
That said, the downside to using regular ole common hardware store bolts is that they do not have enough threads on them so that you can incorporate that little thin keeper nut that is used on the standard factory Farmall bolt. That thin nut must be discarded when using regular ole bolts so that you have enough threads to tighten with where the outer nut and lockwasher goes.
Not having the little thin keeper nut does makes it a little harder to assemble everything, but still quite doable without that thin nut.
I imagine you could go to a bolt store and get special bolts that have more threads on the shanks, but you will pay a premium to go that route. (FWIW: I have purchased 2 used hubs for Farmall's from salvage yards and none of the bolts have ever been re-usable. 60 to 70 years old and likely a factory grade 2 bolt to start with has usually taken its toll so much so that I do not trust em)
This post was edited by rankrank1 at 19:01:51 05/30/14 2 times.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
