Re: 362174-R1 Head on an M??
Posted by D Slater on May 31, 2014 at 17:38:04 from (184.14.189.110):
In Reply to: 362174-R1 Head on an M?? posted by IAtractorKid on May 31, 2014 at 16:28:45:
Be okay with most step heads unless its some kind of special steped head. IIRC. the 8060 is about 200 CC combustion chamber and the 362174-R1 around 180 CC. Be nice if you got a 400 or 450 valve cover and used the opening in it to pipe to the air cleaner inlet. 362174-R1 doesn't have the ventilation hole in head rear and uses no line over the rocker arms like a 8060. Uses about a 2 inch long I/4 inch pipe nipple in the front ventilation hole, then out the valve cover to air cleaner inlet. Use a PVC hose to connect.
This post was edited by D Slater at 03:43:20 06/01/14.
