Posted by DUSTIN KENT on May 31, 2014 at 19:20:58 from (172.4.23.22):
I bought a 1964 case 424 with a international harvester bd 154 that someone tried to rebuild.the engine was locked up, someone did a bad job on resizing the rods.It has new pistons and I would like to make sure they are on the rods the wright direction. there is no arrow on the top of the piston. the piston size is on one side of the piston top, there is a notch on one side on the underside of the piston THANKS FOR THE HELP DUSTIN
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
