My question is why? Not being rude by any means but 12 volt on these machines is nice plus you can use the battery in just about any other machine then. If you have to buy a generator and a 6volt battery you'd probably be in it just as much to buy an alternator and 12 volt battery. I have one that is still 6 volts but it going to 12 as soon as i get the time to change it over. Plus you'd have to get new lights(assuming you have them) or else they would be very dim. Now if you are going for a true restoration to original specs by all means go ahead. And some had the regulator on the genny some mounted under the gas tank(sort of). It wont hurt it to put it on the genny.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
