Re: Injector pump problems international 454
Posted by JimB2 on June 01, 2014 at 05:41:45 from (99.240.243.222):
In Reply to: Injector pump problems international 454 posted by MAH on June 01, 2014 at 05:00:50:
third party image
Hi, with reference to photo of injection pump, the START position is where the fuel control lever just clears the end of the Shut off plunger. In the START position additional fuel is delivered to the injectors.
Hope this helps
JimB
