To get back to your original question, in '45 the generator would have had the regulator (actually just a cut-out) mounted on top. It would have a 4-position light switch (L H D B) to control the charge rate.
As far as the conversion to 12-volt, I can relate. Every tractor I have gotten that was converted, was a half- @**ed job. They have misaligned belts, poorly mounted components, bad wires etc. One even had some Romex wires! Since it needs to be done over from scratch, it is just as easy to convert it back (using perfectly good components somebody else is discarding). The only drawback is the cost of 6-volt batteries, which seems to vary a lot from one place to another.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
