I had a 45 H that had the "factory" 6 volt system. You will need the following:
1. What they call a third brush generator, with a cut out relay
(voltage regulator) mounted on top. Be sure you buy one that already has the original pulley & fan on it, & hopefully the original cut out relay as well. DELCO P/N 1101423
2. Bulb replacements for the head & work lights.
Westinghouse # RP-11
3. Large 00 (double ought) battery cables, ( or used welder cable) be sure to solder the connections, and use shrink wrap on the connections. The positive should be connected right at one of the starter mount bolts.
4. Buy the highest cranking amps 6 volt battery, I have had very good luck with the new Optima battery # 9010-044. They won't rot out your battery box either.
5. If your existing wiring harness has been butchered, I would think about either purchasing a replacement, or wiring it yourself.
I would purchase a complete used original one & rebuild it before you install it. Parts for any H are plentiful, they sold quite a few over the years.
This post was edited by rhtx55 at 12:46:16 06/01/14 2 times.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
