Re: brake adjustment
Posted by FBH44 on June 01, 2014 at 13:49:01 from (64.85.216.119):
In Reply to: brake adjustment posted by oldtanker on June 01, 2014 at 10:16:54:
Don"t really konw, but you might try my "H" adjustment procedure. Might be the same or very similar;
To Adjust / Tighten Up "H" Brakes;
[To Move Brake Pedals Closer to Transmission Cover; ]
 Un-do bottom locknut on bottom of brake drum housing.
 Re-adjust bottom square-head bolt up firmly, then back down ~ ½ / ~ ¾ turn.
 Tighten the bottom locknut BUT NOT TOO TIGHT, you may rip it out.
 Remove cotter pins from clevis pins.
 Un-do the rear portion of the long brake springs.
 Remove the clevis pins to free up the adjustment clevis.
 Thread IN [DOWN] the clevis to tighten up the brakes. [1 full turn moves brake pedal ~ 1/8” closer to transmission cover.]
 Reassemble.
 Do each side evenly, so tractor brakes evenly left/fright.
