Re: Rust in Gas Tank
Posted by 504 on June 01, 2014 at 21:16:11 from (199.127.54.155):
In Reply to: Rust in Gas Tank posted by Bohn Super C on June 01, 2014 at 15:36:36:
What Kirk says, I hurry the job a little by using a shop vac set to BLOW air into the tank. If you try to vacuum it out, we will send flowers for the funeral.
