Re: Super C no spark - changed everything twice still no spark
Posted by Buzzman72 on June 02, 2014 at 08:32:36 from (74.138.170.6):
In Reply to: Super C no spark - changed everything twice still no spark posted by mkirsch on June 01, 2014 at 18:05:24:
Check your wiring from the coil TO the distributor. Is there a wire that's grounding out because of a bare spot? Or maybe the conductor in the wire itself is bad [hey, it happens]. Run a jumper wire from the coil to the points side of the distributor...if that changes anything, replace the wire.
