Re: Super A Hyd. Pump Seal
Posted by charlie M on June 02, 2014 at 10:31:17 from (24.39.229.234):
In Reply to: Super A Hyd. Pump Seal posted by Dalex on June 02, 2014 at 10:13:58:
If you can get a number off the seal you can go to NAPA and probably get one.
