Re: Super A Hyd. Pump Seal
Posted by El Toro on June 02, 2014 at 10:49:56 from (96.244.7.206):
In Reply to: Super A Hyd. Pump Seal posted by Dalex on June 02, 2014 at 10:13:58:
third party image
Here's the breakdown of the Pesco pump. Hal
Item number 11 may need a speedi sleeve if it has a worn groove from the old seal. Hal
