Disconnect the coil to distributor wire at the through post on the dist. Connect that terminal end on the wire to a good condenser wire, and ground the condenser body. With 12v to the ign side of the coil, touch the lead and condenser wire to ground, it should spark a little, as it is acting as points. When you break this connection to ground, the coil should spark. If it does not it is a bad coil. This process eliminates the distributor all together. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
