Re: Super C no spark - changed everything twice still no spa
Posted by John T on June 02, 2014 at 13:01:20 from (216.249.72.121):
In Reply to: Re: Super C no spark - changed everything twice still no spa posted by mkirsch on June 02, 2014 at 10:05:56:
YIKES MK you done tried everything and still no spark grrrrrrrrrrrrrr lol
I think Id just use some small jumper wires and run a hot wire to the coils input (NOT to distributor) and have another small jumper wire on the coils output. Still have a plug/coil wire out the coils top HV tower to a plug or just within 1/4 inch from frame. Take the coils small output (normally to distributor) jumper wire and touch it to frame and then remove it EACH TIME ITS ON THEN REMOVED THE COIL WIRE (or plug) SHOULD FIRE TO FRAME.
This completely by passes any condenser or points problems or cap and rotor problem, so if the coil conducts current and then its interrupted it should fire unless its a bad coil!!!!!
John T
