Re: IH 464 clutch replacement
Posted by AL KUNZ on December 26, 2000 at 08:58:43 from (207.32.17.21):
In Reply to: IH 464 clutch replacement posted by Jerry on December 26, 2000 at 05:32:36:
jERRY if you hang the pressure plate and clutch disc on the in put shafts of the transmission. and then slide the tractor together and reach up thru the bottom inspection hole and install the pressure plate to flywheel mounting bolts. If you do it this way you should have no problems.
good luck.
Post A Followup
: Re: Re: IH 464 clutch replacement
